Order Ford 9N Parts Online
9N Gas Leak Help
Karl
03-20-2002 09:53:40
Happy Spring!
I just reconditioned my gas tank, got new line, filters, bulb etc.. put is all together, tractor works fine, HOWEVER, a new gas leak where the bulb assembly screws into the tank. I had used teflon tape from the start, should I use something else. How can I stop this leak the best?
Also, there was a leak on the back side of the assemby where there is another port. This has a screw in it. What is that for and should it be sealed up tight?
Thanks!
Gord Ontario
03-20-2002 17:27:24
 Re: 9N Gas Leak Help in reply to Karl, 03-20-2002 09:53:40
The stuff youwant to use is Loctite PST (pipe sealant with teflon). I had the same problem, and it fiex instantly. The beauty of it is that you dint need to remove the gas valve, just back it out a fw turns, apply the sealant in a thin bead arounf the threads, and screw back in. A little leaking gasoline will not affect the performance.
Salmoneye
03-20-2002 09:59:34
Stuff in a tube on a yellow and red blister-pak called Seal-All or Seals-ALL...I have applied this to weeping tanks without removing the fuel and drying.
Says on the package that it works through gas and if has been my experience that it does.
I would empty the tank, remove sediment bowl, coat the threads and reassemble...
