Order Ford 8N Parts Online
8N-B *8N380077* External lubercation points on 8N
David Coshman
11-07-2000 03:48:28
After "pressure washing" my 8N, I discovered a "grease-fitting" on both front "pivet-housings" toward the back. How often should grease be forced into the fittings?
Likewise, how many other "external lubercation points" are on an 8N, and how often should they be greased?
ALL RESPONSED ARE WELCOME
Dave Todd
11-07-2000 10:25:52
 Re: 8N-B *8N380077* External lubercation points on 8N in reply to David Coshman, 11-07-2000 03:48:28
David, On the 8N, there are grease fittings on each spindle, (back side of spindle in the middle)then each tie rod end has one, the clutch pedal pivot point on the left side of the tractor has one, then one on the leveling box and one on the leveling box fork. The book recomends to grease the fittings every 10 hours of operation. There should be an oil cup on the rear bearing of the generator which needs oiled every 300 hours. If you have a side mount distributor, there is an oil cup there too and it should be oiled every 10 hours. Hope this helps!!
Dave
Nogrimace
11-07-2000 04:40:36
I don't know how many are on the tractor, I'm sure there are some that have broken off and unless you have a manual to show there lubrication points your going to have to hunt and find. As far as how often to service them, well, I do it annualy just before I cut hay. Then after I'm done. This way you know it's greased. It's better to grease them, depending on use, than have them go dry and have to replace a ball joint or something. Good luck, nothing better than have grease all over ya when your hand pumper goes dry and ya have to fill it up by sticking it into a 5 gal container. Course now they just by "replaceable" cartridge type grease tubes. No fun in doing that, it's way to clean.....up to ones elbows in grease helps to disgard the empty beer cans, if you can hold on to them. Good luck. I think if you check the web, 8N tractor questions and answers it will give you a lead?????
