Lacking power /50' 8-N
Bob McCoy
03-16-2002 14:09:15
This tractor starts well, runs well untill you put it under a load,then it wants to bog down. compression dry-around 86/87 psi wet- 100/105 hot- 110 could it be the gov? Thanks in advance,Bob
pretty good guess . . . Dell (WA)
03-16-2002 14:27:05
 Re: lacking power /50' 8-N in reply to Bob McCoy, 03-16-2002 14:09:15
Bob..... while the compression readings are not braggin' rights, they're good 'nuff, Ford specs: 90 psi min, I'd say yer close 'nuff.
To quick check yer governor, fiddle with the carb linkage while yer standing along side and watch what the governor levers try to do. Disconnect the carb to governor lever (spring loaded ball joint. and watch as ya goose yer carb by hand.
Then get out yer I&T FO-4 repair manual and do a governor rebuild. Not rocket science..... ...Dell
