Order Ford 9N Parts Online
9n Brake Repair and Leaks
Karl
03-12-2002 10:10:18
Hi All,
Question 1: how hard is it to repair, adjust, fix the brakes on a 9n? My brakes won't hold the tractor on a 30 degree slope.
Question 2: I have slight leaks from under center engine block and rear. Perhaps an oil additive to stop leak in front? And as for the rear, would that be oil, transmission fluid or even hydrolic??
Thanks,
Karl--
Scott
03-12-2002 18:30:34
 Re: 9n Brake Repair and Leaks in reply to Karl, 03-12-2002 10:10:18
Sometimes the 9N axles don't want to come out of the housing, you can use a brass or alum. pin to punch on the studs and drive them through the housing. Remove the clutch rod pin, remove axle, loosen the square adjuster then pull the brake assembly off the axle, if there were paper gaskets on each side of the brake assy. measure them you must buy the new metal shims to replace the paper ones, if the shoes have oil on do not reuse them, take the axles to your dealer to get the seal replaced and you may need a speedy sleeve if the seal wore into the axle, usually the bearing and cup are pitted so have them replaced while apart, when reassembling try the thinnest size shim on each side of the brake plate, check for end play (both wheels need to be off) you should not feel any in and out movement and the other axle should go the opposite direction, if not you must change the shim thickness, after correct coat them with gasket sealer NOT SILICONE.
Barnstormer
03-12-2002 10:52:13
Karl, you are scaring me. 30 degrees is very steep. The Hummer does only slightly more than that.
To replace the brakes on the 9N/2N, you have to pull the drum and axle assemble. When going back together you may have to put a slight corner break on the edge of the shoes to get the drum back on.
For leaks, fix what is leaking. Additives may plug up other things and cause more harm.
The transmission, hdraulics and differential all use the same oil, about 5 gal. total
karl
03-12-2002 10:59:28
 Re: Re: 9n Brake Repair and Leaks in reply to Barnstormer, 03-12-2002 10:52:13
the 30 degrees maybe a bit of an exaggeration...
Barnstormer
03-12-2002 11:23:26
 Re: Re: Re: 9n Brake Repair and Leaks in reply to karl, 03-12-2002 10:59:28
It can feel like a lot more than 30 degrees when you are trying to stay on a slippery seat.
If you haven't gotten a manual yet, I strongly recommend that you do. That, and the experience available on this board, should get you through your repairs. I bought the book then made several copies to use. I get grease elbows to a--and would have to buy a new book regularly. I also keep a copy at work (for lunch time reading) :-)
