2N Problem?
Jay 2NSC
03-07-2002 15:19:19
I have searched the archive's for a couple of hour's to no avail.Maybe someone can point me in the right direction?I was grading my dirt road when the pump started making a thumping noise when I pulled up on the quadrant,the box blade lifted but will not come down when you lower the lever?It will leak down slowly,once I turn the tractor off.I noticed the quadrant(cork)friction clutch has broken all apart.The last half inch peice was hanging from the bottom of the lever.Could it just be out of adjustment?Could my stuck clutch play a part?Any help I would greatly appreciated.Your friend,Jay 2NSC
DON TX
03-07-2002 20:54:06
 Re: 2N Problem? in reply to Jay 2NSC, 03-07-2002 15:19:19
You might try posting as a "lift problem". May get more response. The same lift is on all N's. DON TX
