Order Ford 8N Parts Online
8n Hydraulic Problems
Brian W
03-05-2002 06:05:17
On my 1950 8n tractor, my PTO is engaged and working but my hydraulics will not raise or lower. I hve removed my inspection plates and have observed no appearent leaks but I have noticed a steady stream of oil rushing to the right side of the pump compartment. Is that normal? And can anyone suggest what might be wrong with my system? and how to correct the problem...Thanks
ZANE
03-06-2002 05:13:25
 Re: 8n Hydraulic Problems in reply to Brian W, 03-05-2002 06:05:17
I just a few weeks ago got into a job that throughly confused me for a while. I did everything I knew to find why a 9N lift I was trying to fix had insufficient pressure to raise a load with the three point hitch.
I finally removed the pump and naturally the gasket was destroyed in the process so I could not tell by looking at it if the gasket was blown out at the pump pressure outlet hole to differential housing pressure hole where the tube is connected that goes up to the lift.
I tested the pump by drilling and tapping the pump outlet hole and installing a grease fitting and then pumping a grease gun into the fitting to see if the pump housing was broken which I suspected. I could find no break in the pump housing or any of the gaskets to the pump heads that were leaking. The safety relief valve did seem a bit weak and I replaced it while I had the pump out.
I replaced the pump gasket with a new one and cleaned all the old gasket from the mating surfaces. Replaced the pump and it raised the load like it should.
I determined that the problem must have been that the gasket was blown out so that the oil was going back into the lift reservoir chamber and I could not detect it because of it's location being inaccessable with the pump installed.
Paul8n
03-05-2002 07:33:17
What position is your control lever in? Draft control or position control. Before I changed my fluid mine wouldn't work with the small lever under seat in the vertical position. Probably of no help but thought it might help. Paul
llamas
03-05-2002 06:47:51
The issue is not where the oil is going to but where it's coming from and when.
Do you see this "stream of oil" all the time, or only when you have the touch control lever in the "lift" position? Can you get any idea of where it's coming from? It's normal fro the oil to be moving around some, and you'll see the ryhthmic pulsing of the oil around the pump drive eccentrics, but any jet or stream of oil is not normal and is likely the source of your troubles.
Tell you what. Study a diagram of the pump arrangment, then drain between 2 and 3 gallons of oil out of the thing and try running it that way - there will be enough oil for the pump to get suction, and you'll be able to see more clearly where the stream is coming from. Report back what you find and we'll be able to zero in on your difficulty.
HTH
llater,
llamas
bg
03-05-2002 06:28:18
Look inside with the PTO engaged. What happens when you move the touch control? (You should see the long control arm move slightly as you raise and lower the touch control.) If nothing happens, you probably have a stuck valve or some dirt in the valve seat. With the engine off, take your hand and follw the control arm to the bottom of the sump and make sure that the end of the arm is engaged in the little socket on the control valve. If the problem isn't obvious at this point, you'll probably have to drain the system and drop the pump to clean/inspect it.
