Order Ford 8N Parts Online
4 blade or 6 blade fan on 8n
Larrys8n
03-03-2002 11:44:36
My early 8n has a 6 blade fan on it. I have noticed some with a 4 blade,which is the correct one. Thanks Larrys8n
Scott
03-03-2002 16:52:21
 Re: 4 blade or 6 blade fan on 8n in reply to Larrys8n, 03-03-2002 11:44:36
The 1947 and early 1948 8N's had the 6 blade on from the factory like the previous 9N, then they swithed to a 4 blade which was used through the NAA, Ford later discontinued the 4 blade and said to use the 6 blade.
Layne
03-03-2002 12:29:48
I Believe most 8ns came with a 4 blade fan. But if they had a conversion, or for the heck of it the put a 6 blade fan on there for better cooling efficiency. Is It a push or pull fan? hope this helps.
:^0
layne
Larrys8n
03-03-2002 12:51:18
 Re: Re: 4 blade or 6 blade fan on 8n in reply to Layne, 03-03-2002 12:29:48
Layne,I didn't know there were a push or pull fan blade. This blade pulls the air through the front of the radiator.Thanks for your reply,Larrys8n
Layne
03-03-2002 13:58:02
 Re: Re: Re: 4 blade or 6 blade fan on 8n in reply to Larrys8n, 03-03-2002 12:51:18
I think the early 9ns had a push fan to keep air from blowing on the driver. this sucked up HOT engine air and put it in the radiator and thus overheated the 9n frequently. Pull fans were later introduced and helped alot. some conversions had either or.
:^0
layne
Salmoneye
03-03-2002 13:14:46
Hey Larry,
I also have a 6 blade puller on my early (48) 8N...
