12/6 volt battery
Doug 8n 320368
03-02-2002 09:11:12
Have any of you heard of a battery, that cranks the engine on 12 volts, then switches to 6 volts once the engine is started. One of my friends swears there is such a battery.
ED-Illinois
03-02-2002 13:32:48
 Re: 12/6 volt battery in reply to Doug 8n 320368 Ohio, 03-02-2002 09:11:12
Yup - A while back I mused that there should be a way with two six volt batteries wired in series, to produce 12 volts for the accessories on an N while wiring them paralel to keep it a six volt charging and ignition system.
Someone told me about just what you mentioned. I believe JC whitney has them.
bj/8n/mt
03-02-2002 09:18:03
Doesn't work exactly the way you describe it but six/twelve batteries do exist
www.antiqueautobattery.com
YOur mileage may vary
John,PA
03-02-2002 09:16:57
I believe that you are talk'n about "storage battries". Or as Zane would say" Ground Power Unit".
