2n front main seal
John 43 2n
02-28-2002 16:07:17
Is the upper front main (crankshaft) seal held by the the timing gear cover. I just can't remember.
ZANE
02-28-2002 18:15:56
 Re: 2n front main seal in reply to John 43 2n, 02-28-2002 16:07:17
The front crankshaft seal is a rope worm type seal and the top and bottom are held in a groove. The top in the timing cover and the bottom in the oil pan. The pan and or the timing cover must be removed to replace either. Or the top half can be replaced if the crankshaft is removed. The top or upper cranshaft seals can't be replaced with the crankshaft in place.
roperboy
02-28-2002 18:11:38
yes, the seal is in a groove in the timing cover.
