Order Ford 8N Parts Online
8N ran out of gas won't restart
Herb Hickle
11-01-2000 14:48:10
Ran the 8N out of gas. I filled the tank but can't get it to start. Fuel value on, lines to carb clean and fuel flowing, I crank and crank but nothing, once it ran very briefly but rough and died. I have a trouble shooting list that I am using have covered all of thepossible fuel problems except stuck float value. Local mechanic thinks it just needs a tuneup to get up and going again. He thinks it is the points.
younganddumb
11-01-2000 21:44:52
 Re: 8N ran out of gas won't restart in reply to Herb Hickle, 11-01-2000 14:48:10
Check for earwigs in the tank,they like to clog things up.
Bill in Houston
11-01-2000 17:55:49
Hi Herb;
I agree with Danny, check the basics. Get a can of starter fluid and spray into the carb, if it does not fire, then it may be spark. (on the farm, we took a rag and soaked in gas and held that to the carb. Too far to town) for spark either pull a plug or if you have kids.... you know what to do. Good luck..
Regards
Bill
Bill in Houston
11-01-2000 17:55:01
Hi Herb;
I agree with Danny, check the basics. Get a can of starter fluid and spray into the carb, if it does fire, then it may be spark. (on the farm, we took a rag and soaked in gas and held that to the carb. Too far to town) for spark either pull a plug or if you have kids.... you know what to do. Good luck..
Regards
Bill
Danny in CO
11-01-2000 15:17:18
When you ran it out of gas, did you turn the key off? Once I didn't and I burned the points. It wouldn't start.
Check the basics: that you are getting gas & air to carb, spark to plugs, and the correct timing. If you do, it should start.
LazyHorse
11-01-2000 15:16:35
If you ran her dry, you more than likely sucked all the sludge & gunk from the bottom of the tank into the carb. I would take the carb all apart and clean her out good. Make sure you use the little tube on the can of carb cleaner to blow through all the holes.
JOHN
11-01-2000 21:08:21
 Re: Re: 8N ran out of gas won't restart in reply to LazyHorse, 11-01-2000 15:16:35
Sometimes it is a combination of things. I have done the same thing with regards to sludge, and that caused the float to stick, which enabled me to pump gas into the crankcase. After changing the oil, rebuilding the carb, I had to take the gas tank off, clean it, and coat it with an epoxy type material. Next,I found that I had left the key on,I had run the battery down, and had burned the points. Kind of expensive and a lot of trouble for a little carelessness. Actually I guess you could look at it as deferred maintenance
Good Luck, John :>)
