6 or 7 foot
Wayne
11-01-2000 10:41:56
I'm considering purchasing a 7 foot back blade for my 8N but don't know if it's too much. Would a 6 footer be easier on it? Any comments appreciated.
Jim WI
11-03-2000 10:34:16
 Re: 6 or 7 foot in reply to Wayne , 11-01-2000 10:41:56
I've a 7-foot King Kutter blade on my 2N (well under $200 at Mills Fleet & Farm). It looks like the same blade that dave #1 has (see his post for a link to the old discussion).
I can turn the blade around but it does touch the tires during the process. To fix this, I could spread the tires out one notch -- I just haven't wanted to wrestle liquid-filled tires around. It's a low-priority project for me (along with fixing the tire chains).
Fessman
11-01-2000 15:23:05
Wayne,
I have a 7 ft blade and it works great. Depending on the length of the top link I may be able to spin the blade around. The design of the blade allows for easy offset. I find this a nice feature.
Fessman
Rick In ut
11-01-2000 11:09:24
I don't know what type of tractor you have, but a few weeks ago there was a post on the board about a 7 foot blade, problem was he had an "N" tractor and when he went to swivel the blade 180 degrees it hit on the tractor tire.....He was going to cut 6 inches off each end to allow the thing to clear the wheel. Good luck.
dave#1
11-02-2000 04:29:00
 Re: Re: 6 or 7 foot in reply to Rick In ut, 11-01-2000 11:09:24
That was me that posted about the 7' blade hitting the tires, What I found is, not all blades(of any size) are built the same, some are longer than others(From where the mounting pins are to the pivit for the blade),mine is shorter than most so when I try to spin it or angle it, it hits the tires. I also learned that useing Draft control for bulk work is where it's at, then use poision control for finish work.
later,dave
Dell (WA)
11-01-2000 11:05:22
Wayne..... ...Arn't you lucky, 8N's have both position control and draft control. Thats that little handle under your seat (its not for flushing, grin), up for position, horizontal for draft. I just got thru blading my gravel driveways with an 8 footer in draft control. If your tractor can't handle the load in draft, just up the hydraulic lift a little and reduce the draft. Then I finished off in position control. I was really impressed how my draft control worked. If the price is right, I'd go with a 7 ft..... ..Dell
