Order Ford 8N Parts Online
8N Throttle Question
Tom Mull
02-17-2002 19:32:13
I have a 52 8N. When the throttle lever is opened, the springs on the carb pull the lever almost all the way closed. When I drive it, I have to hold the lever to keep it from closing.
Is this the way the throttle is supposed to be or can I make any adjustment so it will stay where I set it? If so, what do I need to adjust? Thanks.
bg
02-17-2002 21:08:48
 Re: 8N Throttle Question in reply to Tom Mull, 02-17-2002 19:32:13
There's supposed to be a spring #9827 that goes from a tab #9855 on the flywheel housing back to the bottom of the throttle arm. Also there's ball-bearing on the throttle lever where it rides on the throttle quadrant plate ridges.
