Order Ford 8N Parts Online
1949 8N
George P.
02-11-2002 11:06:11
My tractor steers easy to the left, but when turning back to the right it seems to bind up and is very hard to turn the steering wheel. Any help with this problem would be greatly appreciated.
George P.
02-11-2002 15:26:45
 Re: Re: 1949 8N in reply to Bill (VA), 02-11-2002 14:41:09
Thanks Bill for your quick response.I have taken the steering box off and it does need the top bearing.I have'nt had a chance to tear the box the rest of the way down, but will do that tomarrow. Thanks again. George
Bill (VA)
02-11-2002 17:55:52
 Re: Re: Re: 1949 8N in reply to George P., 02-11-2002 15:26:45
I don't know if the 49's are the same gearbox or not as my 47 but I have a word of warning .. the top of the gearbox can be reassembled backwards.. all went together fine for me until I tried to get my dashboard back over the steering column and bolted to the steering gearbox. I swear the picture is wrong in my service manual of the assembled gearbox!!... anyway after tearing it all apart and reversing the top of the gearbox all went together smoothly.
George P.
02-13-2002 10:25:14
 Re: Re: Re: Re: 1949 8N in reply to Bill (VA), 02-11-2002 17:55:52
I see as how you could put the top of the gear box on backwards and will take care to try to prevent that problem. Thanks for the help
bj/8N/mt
02-11-2002 13:23:06
 Re: 1949 8N in reply to George P., 02-11-2002 11:06:11
As you have surmised something in the steering is binding. Over a fifty year life lots of things in the steering can get bent. Also joints like a shot of greese every twenty years or so. Easiest way to isolate the trouble is to jack all of the weight off the front end and see if you can see something binding. If not try disconnecting the drag links and see if that helps. If not it is likely in the steering box but I wouldn't tear into that until I did the above.
Your mileage may vary
George P.
02-11-2002 15:34:33
 Re: Re: 1949 8N in reply to bj/8N/mt, 02-11-2002 13:23:06
Thanks for your quick response. I already did everything that you said,and the steering turned fine. The steering only binds up when the front wheels have weight on them.
bj/8N/mt
02-11-2002 17:26:39
 Re: Re: Re: 1949 8N in reply to George P., 02-11-2002 15:34:33
Now you see why I rely on Dell for all of my heavy duty mind reading. If you have been there on bent; broken; under lubed then Bill above has it nailed--top steering gear bearing
George P.
02-13-2002 10:27:37
 Re: Re: Re: Re: 1949 8N in reply to bj/8N/mt, 02-11-2002 17:26:39
Thanks for your help
