2N Cylinder Head Gasket and coolant in oil
Dean Peters
02-10-2002 16:46:16
My 2N engine was recently re-built and after very few hours I had a coolant in the oil problem. Removing the head revealed a blown gasket near the center bolt. I think the gasket had too small a hole for the coolant to move from the head to the block. A new gasket (with an 8N part number) has the same smaller hole (than the coolant channel). Are 2N and 8N gaskets different? Also, should I drop the pan and clean out the coolant?
