Lift arms........How high??????
Mark
02-10-2002 13:54:29
I recently remove my entire hydraulic pump on my 48 8n and disassembled it. I cleaned everything I could think of. I replaced all of the gaskets and fixed the cam follower pin. My question is why am I not getting the full 30" of travel out of the lifting arms. When the arms are at a complete rest they are about 3" off of the ground. When I raise them to the highest point they are only 23" off the ground. When I operate them it is smooth with no hesitation. Can you guys get me straightened out PLEASE.
Thanks Mark
Gaspump
02-11-2002 06:44:09
 Re: Lift arms........How high?????? in reply to Mark, 02-10-2002 13:54:29
Change your lever from draft control to position control, with lift operating run them up and down and check the heights. In draft control the lift arms will drop 3" lower than in position control and should raise to near the same. The setup is well outlined in the new FO-4. Keep your lift in position control when nothing is attached to keep the lifting rods from wearing on the axle housing.
Mark Hendershot
02-10-2002 20:15:52
I have a Ferguson but the same set up. My arms go down to around 3 inches off the ground and lift up till they jam tight on the chains at max height of around 28 inches or so. Never measured it befor. They should go down to about 3 inches tho. Maybe Dons arms that go from the lift arms to the Link assembly bars are to short? Not sure. Mark H.
DON TX
02-10-2002 15:14:10
My 51 8N lift arms at rest are @ 12" off of the ground. That would account for the difference. DON TX
Mark
02-10-2002 18:44:06
 Re: Re: Lift arms........How high?????? in reply to DON TX, 02-10-2002 15:14:10
How do you fix that?
Thanks Mark
SORRY --- DON TX
02-10-2002 20:00:05
 Re: Re: Re: Lift arms........How high?????? in reply to Mark, 02-10-2002 18:44:06
I'm not that far along in my IT-FO4 shop manual yet. Hadn't had a reason to work on that part. I've spent all my time on the other end or in the seat. I do need to adjust and inspect one of these days. Did you not work with a manual? You got more guts than me. Sorry I can't help. Someone will. DON TX
