Order Ford 9N Parts Online
9N front transmission seal
zz
02-04-2002 10:09:50
Can anyone give me specific information on replacing thi seal?
Will I be able to get to this seal from the front of the trans after splitting the trans from the engine?
Does the steering mechinism have to come off?
Any pointers on this job?
Thanks zz
TimK
02-04-2002 11:24:11
 Re: 9N front transmission seal in reply to zz, 02-04-2002 10:09:50
I suspect that the leak you are seeing if it is really bad is not hydualic oil, but engine oil from a bad rear seal. Don't be surprised once you change the trans seal that you are still leaking oil. If it is mostly engine oil, then I wouldn't replace the seal on the trans at all unless I were ready to do an engine rebuild. My $.02
zz
02-04-2002 12:00:47
 Re: Re: 9N front transmission seal in reply to TimK, 02-04-2002 11:24:11
Thanks for the $.02 TimK...It's definately 90wt...where I park the tractor is on a slight decline towards the front.Enough I guess to put the oil level above the seal..it's a steady drip about 2qts worth in a weak.
john,PA
02-04-2002 10:35:41
I believe that I would undo the steering at the tie rod ends.
After splitting the tractor at the transmisson, you should be able to replace the front seal with no problem. Are you sure it is leaking? It might be a good time to check clutch plate too.
zz
02-04-2002 11:20:39
 Re: Re: 9N front transmission seal in reply to john,PA, 02-04-2002 10:35:41
Thanks johnPA....Yes I'm sure it's trans fluid leaking...I had noticed that the level was down and thought that it was a good time to replace it...drained it and put in 5 gal 90wt... I noticed it dripping out and sat a tub under it ..It leaked about 2 qts in a week ...it's leaking from beneath clutch....
And I'll take your advice on checking the clutch when it's apart,and anything else I can see in there
Is the rear engine seal accessable at this point?
Quickdraw
02-04-2002 11:48:21
 Re: Re: Re: 9N front transmission seal in reply to zz, 02-04-2002 11:20:39
Hi zz, let me know your email address and I will send you a couple of pictures of my 9n split, a picture is worth a thousand words. I'd post the pictures here but still haven't got the software to upload to my web space yet, hard to get free for a mac. Good luck.
zz
02-04-2002 12:15:19
 Re: Re: Re: Re: 9N front transmission seal in reply to Quickdraw, 02-04-2002 11:48:21
I mailed my email address to you Quichdraw...thanks for the help
zz
terry
02-04-2002 15:24:30
 Re: Re: Re: Re: Re: 9N front transmission seal in reply to zz, 02-04-2002 12:15:19
zz,I tore my 9n down to do the same thing but decided while I had it apart to put a sherman trans in, also if you have been leaking trans oil just replace clutch because if any oil got on it it will break apart later then you have to split the tractor again,I also am rebuilding bottom half of engine, top half in very good shape there is no better time to check things then while you have split. If you don't already have one get a IT FO-4 service manual this will help you get the job done and what they do'nt cover in it you can find out here from these guy's.
zz
02-06-2002 12:18:07
 Re: Re: Re: Re: Re: Re: 9N front transmission seal in reply to terry, 02-04-2002 15:24:30
Thanks terry...got the FO-4...where did you find a Sherman trans?
