3-point lift
drdinPa.
10-29-2000 09:49:14
Can anyone tell me the approx. lift capacity of the N-series 3-point hitch when new;or one in good working order.Also what was the maximum psi. from the hydraulic system when in good shape? THANK YOU !
Jim NC
10-29-2000 10:26:34
 Re: 3-point lift in reply to drdinPa., 10-29-2000 09:49:14
Minimum psi is 1600 so I would guess the max to be about 2000-2200 psi. As for the max lift capacity if you can keep the front wheels on the ground it will lift about any implement you can put behind her.
