King Kutter Revisited
bjt
01-31-2002 14:35:23
This is a follow-up to the King Kutter manual thread below....
It's all coming back to me now. I *tried* to get the manual from the King Kutter web site, but the PDF manuals would not come up on that particular day. I was forced to guess at the assembly procedure from the sketches and pictures on the products page. It didn't help that I was missing the spacer/sleeve and the lift pins and had a U-shaped top link pivot that doesn't appear in some of the pictures!
Looking at the PDF of the users and parts manuals today, it looks like I got it right after all:
1. You *are* supposed to bend the heck out of the long supports to make them attach.
2. The 5', 40 hp models don't use the top link pivot. (Does anybody know how this device is supposed to work?)
3. There *is* supposed to be a sleeve/spacer over the long bolt to maintain the correct spacing to get the top link in place. I guess I'll have to fabricate one.
The moral of the story is look under the deck for the bloody manual and if it's not there, make sure to get it off the web site 'cause it tells you the easy way to force the thing together!
Overall, I must sat that I'm very happy with the performance of the unit. It cuts heavy brush with ease and the shear pin at the PTO/gear box attachment works like a charm when you mow over a big wad of old barbed wire and lock up the blades :).
Be safe!
bjt
Jim WI
02-01-2002 10:33:11
 Re: King Kutter Revisited in reply to bjt, 01-31-2002 14:35:23
Look under the belt cover. The manual on my FM72 was taped to the underside of the plastic cover.
Ken in PA
01-31-2002 17:00:30
Mine came with the u-shaped thing and I put it on. I put the top tube through it with the u toward the back of the unit. I figure if the top link is hooked to the u thing it will allow the tailwheel to "float" a little better. Safer than a top chain but still provide some lift in the rear without causing the whole deck to lift like when going from a flat to an incline.
Also the spacers are approx 1.320 OD x 3 3/4" long. I bet if you e-mail Kingkutter and tell them you didn't get them, they will send them to you.
I wish I knew how nice they were to deal with. I needed a manual for my Woods finish mower and the NH dealer charged me $17 for copies stapled together! OUCH
Ken
bjt
01-31-2002 18:23:52
 Re: Re: King Kutter Revisited in reply to Ken in PA, 01-31-2002 17:00:30
Oh, I get it. Put the large diameter hole (toward the U end) over the bolt and sleeve and attach the top link to the smaller diameter hole. Then the unit can pivot up and down on small hills instead of levitating. Cool. I'll see if I can get KK to send me one.
Thanks,
bjt
EDDIE8N
01-31-2002 16:16:47
bjt,
I think that manufacturers of brush hogs stay up most nights thinking of ways to make life difficult for us tractor enthusiasts.
I purchased a new HOWSE brush hog last summer with my tractor. After I was finished with my hogging for the season, I figured on sharpening the blades so it would be already for next year.
I had read through the manual when I bought it and I remembered reading about removing the access cover on the deck to get at the nuts that hold the blades on. Figured that would be the easy way to do it since I could remove the blades to sharpen them.
Only problem was there wasn't any access cover on the deck. Read that section of the manual again, sure enough, you are to remove the access cover. Looked at the picture on the manual, clearly shows the access cover. Go to the parts page, there's the access cover including the part #. Now here I stand, looking at that nice new shiny deck paint that is only 2 months old while holding the manual in one hand and a cutting torch in the other and thinking there's got to be a better way.
Ended up standing the darn thing up on her nose and taking the blades off from the bottom side. After replacing the blades I realized that even if I had an access hole in the deck, it wouldn't have been big enough to reach in with both hands to put the blades back on anyway. Boy was I glad I never lit the torch!!
EDDIE8N
bjt
01-31-2002 16:42:48
 Re: Re: King Kutter Revisited in reply to EDDIE8N, 01-31-2002 16:16:47
EDDIE8N-
It's funny you should mention that.... I have a 3" or so diameter hole in the top of my deck for just such a purpose, but I'm thinking I need three hands on really long arms to get those blades on and off. OTOH I didn't think you were supposed to sharpen the blades. Does your manual tell you to?
bjt
EDDIE9N
01-31-2002 17:28:14
 Re: Re: Re: King Kutter Revisited in reply to bjt, 01-31-2002 16:42:48
bjt,
The way I see it, I sharpen my chainsaw, my pocketknife, my hunting knife, my ax, my lawn mower blades, i.e. everything that is used to cut. Only makes sense to sharpen blades on brushhog (in my opinion).
I do remember something being posted awhile back regarding this matter, in fact I believe it suggested that you shouldn't sharpen them...can't remember now exactly what it did say , but my thought is this: takes less horsepower to cut with a sharp blade.
EDDIE8N
bjt
01-31-2002 18:18:01
 Re: Re: Re: Re: King Kutter Revisited in reply to EDDIE9N, 01-31-2002 17:28:14
Right - cutting blades need to be as sharp as possible for maximum efficiency. I'm not sure, however, that these are cutting blades. I'm thinking this is more of a flail type instrument like a weed wacker or lawn edger in which case dull is better..... I'll have to pull the manual back up and check.
bjt
Dave Smith
01-31-2002 19:10:42
 Re: Re: Re: Re: Re: King Kutter Revisited in reply to bjt, 01-31-2002 18:18:01
The manual with my 6 ft Bush Hog says to leave a 1/16 inch flat edge. I don't know why unless hitting rocks etc. is easyer on it. It sure gets knicked up.
Dave <*)))><
EDDEI8N
01-31-2002 18:57:15
bjt,
Just reveiwed my manual.
It states under operating tips:"The blades will need sharpening when see you that the grass has not been cut evenly or it looks like the grass has been ripped off."
Also under troubleshooting:
PROBLEM----- --POOR CUTTING JOB
CAUSE----- ----BLADES DULL
SOLUTION----- -SHARPEN BLADES
If it's good enough for them , then it's good enough for me.
EDDIE8N
