I have a Jubilee, and before I get to the trouble I should say that I rebuilt the lift ( seals,o-ring )Cleaned the uploading valve and is floating very well. Replaced the Pin that slides on the Cam. It was worn almost in to. When I was done the lift worked very well. Except to lower the lift all the way to the bottom, You had to push the control arm as far down as you could get it.. I thought It needed an ajustment. But I don't know anything about what to adjust. Now the Problem: I was blading the drive way and all was well. I was backing up pushing some gravel and hit a solid rock sticking out of the ground and something popped. After that When I lifted the control lever to the top the lift came up. But if you moved the lever down an inch or two, the Lever would drop to the bottom. So the lift still works but it's at the top or at the bottom of the lever. You can't let go of the lever half way, or the lever just falls. I took the Lift cover off to see if there was anything Broken and It looks fine. Are there any adjustments to get the bottom end up higher on the control lever? Oh yea, When I put it back together again this time it feels like the control arm is moving with more response. I haven't put it back on the Tractor yet... Hope you can help, Thanks in advance J52J/Jess
