Order Ford 8N Parts Online
8N Success at last!
Karen
01-25-2002 14:20:01
As it turns out, there were 2 problems. The reason I could not connect the positive lead to the battery after grounding it to the block, was because my negative lead was not insulated and had been grounded out at some point in time. The solution was to put the positive lead on the negative post and visa-versa. At some point in time I can get an insulated negative lead and put it back the way it should be. 2nd problem, battery still not getting charged after polarizing the generator. My mechanic was able to get it charging for a few seconds then it would stop. He opened up the regulator and said he had only seen this one other time. This new regulator had evidently been sitting on the shelf for so long that the points had oxidized. He attempted to file them to get it to work but no success, so he replaced it. The Ammeter works now as well. Thank you all for your postings. I learn alot just from reading this message board.
Thanks again
thanks . . . Dell (WA)
01-25-2002 16:57:11
 Re: 8N Success at last! in reply to Karen , 01-25-2002 14:20:01
Karen..... .thanks for follow up. As you report, some electrical problems are not intutitively obvious over e-mail but are best resolved by eye-ball and experience..... ..we care, Dell
russell8n462645
01-25-2002 14:52:37
I have a 52 8n negetive ground.It's been working fine for last 15 years. just finished all new wiring . wired per manual except of course batt neg to ground.also wire coming off coil to dist. is from neg. post of coil
uh . . . Dell (WA)
01-25-2002 16:42:21
 Re: Re: 8N Success at last! in reply to russell8n462645, 01-25-2002 14:52:37
Russell..... ..I would caution you against "braggin" about your negative grounded 8N. You loose about 25% of your sparkies with incorrect grounding. You've been lucky so far.
Your ignition coil is internally configured to work best with positive ground. Its an electromagnetic theory thing which I don't want to go into and confuse all the other N-Tractor owners who are having sparkie problems and are electrically challenged..... .....respectfully, Dell
russell 8n462645
01-26-2002 12:39:46
 Re: Re: Re: 8N Success at last! in reply to uh . . . Dell (WA), 01-25-2002 16:42:21
thank you dell, I didn't realize I was it was 25% I am now a proud owner of a positive grd. 528n. repolarized and reversed coil and ampmeter, thanks , hard not to brag about my old work horse. I was a tractor user instead of owner untill recently, am now trying to learn as much as I can to take care of this wonderful machine . I value your opinion.....russell
now thats. . . Dell (WA)
01-26-2002 13:33:51
 Re: Re: Re: Re: 8N Success at last! in reply to russell 8n462645, 01-26-2002 12:39:46
Russell..... .now thats something worth braggin' bout, welcome to the N-Board..... .Dell
unimpressed
01-25-2002 17:37:08
here is info on ip 209.240.222.131
01-26-2002 10:44:14
 Re: Re: Re: Re: 8N Success at last! in reply to unimpressed, 01-25-2002 17:37:08
Re: Kennedy's driver can been seen shooting him
Posted by Joe Mewbourn 209.240.222.131 - 06:45:09 12/20/2001 (0)
Google search for ip 209.240.222.131
Ditto...Don (NC)
01-25-2002 19:30:48
...to anyone (don't know your name so I'll just call you A$$hole) who makes negative remarks without identifying themselves. Get a life...
