Insignia painting
gary
10-27-2000 17:45:05
How do you paint the raised Ford letters? Is there a stencil available?
norm-wy
10-28-2000 09:06:20
 Re: insignia painting in reply to gary, 10-27-2000 17:45:05
Gary
Alot of people have had good luck using a hard rubber roller to roll the paint onto the raised script letters. The roller is similar to the type used for fingerprinting plates, silkscreening or printing. Available at most printing supply houses, craft supply houses and police stations. 8^) FWIW
Mark B (PA)
10-28-2000 05:22:45
If you go with the vinyl "decal" here's a tip. They come on a sheet of backing paper which peels off. It is kind of clumsy and because you can't see thru it, It is hard to position over the embossed ford script on the sheetmetal. Using scissors and patience, I trimmed the decal out of the backing. Made it much easier to position and gave a neater installation.
Although the decal is not the original method, it is probably quicker and more easily redone if messed up.
By the way (for Dell) what is the "felt rocker" ?
Vic
10-28-2000 18:43:47
 Re: Re: insignia painting in reply to Mark B (PA), 10-28-2000 05:22:45
Most self-adhesive decals (this includes reflective striping, by the way) are easiest to install if you wet the metal and decal with water, possibly with a drop of dish detergent to break surface tension. This doesn't sound right to most people, but the water allows you to continually reposition the decal until you're satisfied that it's perfectly aligned. Then squeegee the water out (your fingers work fine for the Ford script) from center to the edge. The water goes away, leaving a perfectly-aligned decal.
That's the way the pros do it, and once you've tried it you'll never go back applying decals dry, in which case you have to have them perfectly aligned before the decal touches the sheet metal. Not easy. It's even harder on 8N fenders, which are compound curves.
By the way, if you do a good job with the decal aligned accurately, and have no bubbles or dirt under the decal, they usually look better than paint (to my eye, anyway). It's very difficult to recognize it as a decal (remember that a couple coats of red paint have thickness, too), and there's no way a paint edge will be as sharp as a decal. If you're restoring a true show tractor, go with paint, but otherwise...
Dell (WA)
10-28-2000 07:29:58
Mark..... .."felt rocker" is my description of a "large" 1 piece, curved, paint pad (felt? velvet?), that you "rock" across the embossed (raised) metal. Available at "professional" arts and crafts supplies stores. (if you know what you're looking for). Used with a very "thick" paint..... ....Dell
Dell (WA)
10-27-2000 22:35:05
Gary..... .have you checked the "archives" at the top of this most excellent N-Board? Used to be great discussion on "how to paint the raised Ford".
Basically, there are stencils, masks, vinyl applique, steady hands and small brush, or the original felt rocker technique. Ya' pays yer monies and takes yer chances..... .Dell
