Order Ford 8N Parts Online
1951 8N-B, STARTER POST SWITCH BY THE GEAR-SHIFT LEVER
David Coshman
10-25-2000 22:20:32
Could somebody please tell me how to remove the "STARTER SWITCH" that is located on the transmission by the "gear-shift lever" If the UNIT could be removed, coud it be cleaned, repaired or replaced.
I am currentley grounding the STARTER BUTTON WIRE against the motor, to engage the STARTER.
PLEASE HELP ME.
ALL RESPONSES ARE WELCOME.
bg
10-26-2000 14:39:57
 Re: 1951 8N-B, STARTER POST SWITCH BY THE GEAR-SHIFT LEVER in reply to David Coshman, 10-25-2000 22:20:32
The switch is not repairable, at least not when a new one is only $10 or so.
Steve IA
10-26-2000 03:04:32
Once you remove the plate the button and the gear shift sit on by removing the bolts it will be obvious how to remove the button. You may need to replace the plate gasket.
HTH Steve 8N169302
Also...
10-26-2000 06:18:58
 Re: Re: 1951 8N-B, STARTER POST SWITCH BY THE GEAR-SHIFT LEVER in reply to Steve IA, 10-26-2000 03:04:32
You may find it impossible to remove the shifter plate if the dash panel fits down tightly against it. On my side distributor one I had to pull the dash to get the front bolts out. ( Pull hood first) You may be able to pull the bolts and slide it upwards and out of the way enough to get it out. DO IT THE RIGHT WAY and replace the switch so you keep your nuetral safety switch function!
Now if we could only get that sticking capsloc key of yours to work we'd be doin' sumpin! ;-)
