Order Ford 8N Parts Online
1951 8n 6v. coil
Keith in Ohio
10-25-2000 15:29:07
Does an original 6v. system, side mount distributor set up require the use of an external resistor? I recently purchased a new 6v. coil that has the words "use with external resistor" stamped on it. The schematics that I have do not show any resistor. Any help would be appreciated.
no.....Dell (WA)
10-25-2000 15:41:28
 Re: 1951 8n 6v. coil in reply to Keith in Ohio, 10-25-2000 15:29:07
The OEM 6 volt sidemount ignition coil does not require any external resistance.
This is not to say that your "replacement coil" manufacturer might think his coil needs external resistance.
Carefully read any instructions (written in 8 different languages except american) that might have come with your replacement coil. There have been reports of "1 size fits all coil" including 12 volt tractors that do have an external "ballast resistor" scheme being sold as a 6 volt replacement coil and the instuctions neglect to make that distinction..... ...Dell
