Jubilee draft control won't behave
gwp
10-23-2000 12:39:49
After all the work I've done on my Jubilee hyd. system...successfully, I feel very intimidated in trying to adjust my draft control for fear of screwing up the whole thing. I've seen the shop manual procedure, but it seems quite complicated and I don't have all the NUDAY TOOL NUMBER# this and that. Is this adjustment as difficult as it seems, or is my imagination overactive??? When I engage the draft, the lift drops. But when I engage it while plowing, it seems like it's trying to work correctly. This isn't a big thing, but breaking a field that's not level is starting to bug me with the plow following the rocking up and down with the tractor. Thanks....Gary
ZANE
10-24-2000 20:26:34
 Re: Jubilee draft control won't behave in reply to gwp, 10-23-2000 12:39:49
I am working on a booklet with pictures that if followed will allow you to properly adjust the lift on your NAA. If you are interested just Email me.
The only special tool needed is a feeler gauge and it is included with the booklet.
The booklet covers the NAA and the hundred series which both adust the same way except that the two use different feeler gauges.
