Order Ford 9N Parts Online
9n-2n engine use
homeboy
10-23-2000 02:55:47
Was the engines used in 9-2n used in the mainstream production, ever used for other than these tractors? Such as maybe the model A Ford or maybe a mobel AA Ford truck? Any ideas????? ??
Scott(Ks.)
10-23-2000 11:54:27
 Re: 9n-2n engine use in reply to homeboy, 10-23-2000 02:55:47
There is a very good book, "Vintage Ford Tractors" by Robert N. Pripps. It is full of information and good pictures of about all Fords. It has alot of odd and standard N's. On page 127 it shows an 8N Funk V8 sitting in front of a 1941 pickup with 119.7ci ford tractor engine!! Some guys have neat toys. The book came from Barnes and Noble.
JimTn
10-23-2000 04:36:12
They were used in trucks in 1941 and in the Ford GP prototype jeep. The jeep had a downdraft carb and front mounted tower dist. The truck had a remote coil and updraft carb.
Larry 8N75381
10-23-2000 16:40:19
 Re: Re: 9n-2n engine use in reply to JimTn, 10-23-2000 04:36:12
Intresting!
Do you know if there was a fuel pump on the trucks and/or jeep? If you look at the side of the tractor block there is a boss that is clearly for a fuel pump. It sits right between the #1 and #2 cylinders and is located in line with the camshaft. This boss even shows in the Parts Catalogs, both the 1946 one and 1949 one. Unless Ford had intentions of using the engine block with a fuel pump, they would not have added the boss because of the expense to have it put on the pattern.
JimTN
10-24-2000 05:06:02
 Re: Re: Re: 9n-2n engine use in reply to Larry 8N75381, 10-23-2000 16:40:19
The truck and jeep engine has a fuel pump. There is no difference in the basic block and head. The front timing gear cover is unique to the jeep and the front timing gear cover on the truck is unique to the truck. Both the jeep and truck used the same oil pan. The n engine was used in trucks for that short period of time as a replacement for the 60HP v8 and was ultimately replaced in 41 with the 6cyl.
Bill In Houston
10-23-2000 10:44:49
The tractor motor to my knowledge did not operate in other vehicles. The Model "A" motor looked similar, but had a larger displacement and more HP (like 40 rated, 30 practical)
