Battery Dying
Mike 8N
10-22-2000 20:02:21
I put a fresh battery in my 8N because the old one (battery) was pretty tired and couldn't really hold much of a charge anymore. The new one seems to be almost as bad. Sounds like some kind of short I guess. What are the most likely places a short can occur? It is 6 volt and with no lights. Maybe I'll find out why the old battery didn't hold much of a charge. Thanks for the help.
Mike 9N
10-24-2000 21:56:19
 Re: Battery Dying in reply to Mike 8N, 10-22-2000 20:02:21
A simple test for Curent Draw / Short is to use a Test Lamp. Disconect one terminal from the battery, attach your Test Lamp between the battery terminal cable and the battery post. If you have any current draw at all the lamp will light. ( You can see this by turning on ignition, light will light) If you have current draw then start disconecting individual wires one at a time tell light goes out, I would be suspect of Regulator also.
Claus
10-23-2000 04:44:31
third party image
Disconnect the 3 wires going to the terminal block. (The 3 wires that go to the voltage regulator, ammeter and the ignition key.) Reconnect one at a time and see if you get current draw. If the current draw is pretty heavy, then you may see a spark when you momentarily touch a wire to the terminal block. If the discharge is low, then you may need a ammeter to see the discharge. The ammeter would be hooked up in series with the lead. Find the lead that causes the discharge and you can trace the lead to the problem. Sometimes the cutout relay in the Voltage Regulator gets stuck and causes the battery to discharge through the generator.
Happy Motoring
Claus
Bill
10-22-2000 20:26:45
Mike are you sure it is a short and not the charging system? (i.e. generator or regulator).
does the battery hold up of you disconnect the battery?
what have you done to check for a short?
Mike 8N
10-23-2000 09:36:35
 Re: Re: Battery Dying in reply to Bill, 10-22-2000 20:26:45
I have not done much so far. I know that the machine runs great for hours when I use it and I assume the gen is doing it's thing. I have never had it quit on me so it seems that I am not running off of the battery power. When the tractor sits for a week or so, it will usually need a recharge to get going again.
