Charlie..... .I believe you'll find that the popular SI-10 alternator has a 3-phase stator and yes a full wave diode bridge for each stage which reduces the ripple of the diode rectifacation of a sine wave. My explanation was an attempt in few words to explain why alternators require "negative ground". It really had to do with the eaze of frabication of diodes with their anodes as part of the metalic case for heatsink purposes. And subsiquently using the alternator case as a larger heatsink. It has nothing to do with reversing the alternator wiring to get a positive ground. On my BMW's, for example, the alternators are "rubber mounted" for vibration reduction (less vibration is a perception of higher "quality" and thus the justification for higher prices) and thus need a seperate "grounding" wire from the alternator case to the engine block. The alternator case is negative. The second reason for negative grounds, is the NPN transistor power amplifers used in radios. The same problem, heat. Using the radio chassis as heatsink required negative ground since the radio chassis was metal and hung from metalic dashboards with metalic shafts. Otherwize you blow your germainium fuses...er...power transistors. Thankfully, the semi-conductor industry has come a loooonnnngggg ways since then otherwize, there wouldn't be computers or this N-Board (grin)..... ..Dell
