8 N valve grind
Walter West
10-19-2000 05:15:37
I have an 8N that ran well last summer, but would not start this year. Compression shows low too none. I suspect the valves are sticking and tried a sonvent and Mystery oil in cylinder head and on valves with covers off. Did not take manifold off yet. If worst came to worst how much time and trouble would it be to do a valve job. I have it in a closed garage and the only problem is winter comming. Walt West
D.L.
06-29-2001 10:47:19
 Re: 8 N valve grind in reply to Walter West, 10-19-2000 05:15:37
8n valve job, I'm in the same boat, or tractor, if you have those mushroom valves, you have a pain in the,(GUIDES) either you get someone to come to you and do a valve job, or you will pull your motor and take it to them, or you could take the whole tractor to a machanic, if you can find one who works on junk, or I'm sorry, antiques, I am changing over to the late style valves, with solid guides, and adjustable lifters, I'm putting in new rings and bearings, and with all this, I will still have an 8n, sometimes I would swear it is a cheve. sorry I got grease on your computer. DL.
Claus
10-19-2000 05:59:41
You need to do the wet/dry compression test to discern between the valves and other causes of low compression. Get yourself an FT-04 Manual. It is full of good stuff...($25.00 CHeeeee ep like Dell sais)
Happy Motoring
Claus
