Order Ford 8N Parts Online
8n Run Problem
Jim in WA
10-18-2000 17:33:43
Help! My 52 8n starts, but won't allow me to increase throttle right away, stalls when I try. Also, the ammeter pegs to +10-20 or so, when throttle increases, tractor generally runs a little rough like out of time. Is my generator going bad, or something else?
Dewey (MI)
10-20-2000 04:59:23
 Re: 8n Run Problem in reply to Jim in WA, 10-18-2000 17:33:43
I trust that you have good gas flow to the carb. Adjusting the intake screw on the carb to increase gas flow may only solve the problem temporarily, if gas flow is your problem.
Charlie in TX
10-19-2000 07:17:51
Not a generator problem.
Does it only not accept throttle when it is cold outside? That is normal. Gas dosn't vaporize as easily at cooler temp.
Dave Todd
10-18-2000 21:02:01
Jim, My 8N will show about 20 amps when I first start it, but comes down fairly soon after it's been running for a minute or two. I think that is normal, and don't see anything wrong with that, unless yours is staying there all the time. Then I would suspect something else. Your generator must be ok if it's charging 20 amps. As for stalling out after start up, try turning the carb adjustment screws out just a touch and see if that helps. I know there are others with more knowlege than I who will surely help. Good luck!!
Dave
