8-N LIFT
KEVIN
10-18-2000 16:02:46
DOES THE REAR LIFT ARMES ONLY WORK OUT OF GEAR WITH THE CLUTCH OUT?
william d. ratliff
02-18-2002 08:52:53
 Re: 8-N LIFT in reply to KEVIN, 10-18-2000 16:02:46
Lift rises fully, then lowers to level about half way up.
Salmoneye
10-18-2000 17:07:43
Uh...
Are you asking if the lift only works when the transmission is out of gear with the clutch engaged?
If so, the answer is no. The PTO/Hydraulics will work with the transmission in or out of gear, but only if the clutch is engaged (foot OFF the pedal).
yes.....Dell (WA)
10-18-2000 16:23:27
Kevin..... .the hydraulic rear lift arms are operated by the PTO shaft driven hydraulic pump. The PTO shaft is directly driven thru the gearbox by the clutch. This means anytime you "clutch" your PTO stops turning and your hydraulic pump stops pumping. Something you get used to. Of course, live hydraulics (2 stage clutch) is nicer, but it is priceyer and not avaliable for N-Tractors.
