3pt wood splitter/front wheel weights
Doc
10-18-2000 01:16:30
I am back with questions. I would like to find front wheel weights for my 8n however I can not find them; any suggestions? I am also interested in purchasing a 3pt wood splitter. Do they work well? What should I look for in one if I find it? Also I replaced the PTO relief valve and when I replaced the right pto cover I don't understand what it does and what the control lever hooks to. I guess I am just confused, and suggestions on this one. I bought a manual however all information seems vague.
Charlie in TX
10-18-2000 09:43:48
 Re: 3pt wood splitter/front wheel weights in reply to Doc, 10-18-2000 01:16:30
Doc, I am a bit confused. You said the the right pto cover has a control lever. The control lever is on the left side, the dipstick is on the right. If you are talking about the left side control lever, I believe it hooks to a coller on the pto shaft. It will slide the collar forward to ingage the pto and rearward to disingage.
Frog Level
10-18-2000 10:34:14
 Re: Re: 3pt wood splitter/front wheel weights in reply to Charlie in TX, 10-18-2000 09:43:48
Actually, the covers are interchangeable. On my 8N the pto shift lever used to be on the right hand side with the dipstick on the left. I switched them around when I did the rebuild.
Don
Dell (WA)
10-18-2000 08:24:37
Doc..... ..unless you have an "external" hydraulic power source, I think you will be greatly disapointed in a 3-Point wood splitter. The internal N-Hydraulics do not provide enuff gph or enuff pressure. Leave alone, the issue of getting the internal hydraulics out. I have seen some neat 3-point mounted wood spliters, but on the N?, I don't think so..... ...Dell
Jim.UT
10-18-2000 07:56:47
I was looking for front wheel weights, too. I put a "wanted" ad in the classified section of this website (free) and got numerous responses. The problem is freight. Unless you get a response from someone close to your location, you're going to spend as much for the freight as you will for the weights. First check any ag salvage yards in your area. I don't have any in my area, so I'm still going without weights. Auction first of next month, maybe something will turn up.
Steve W
10-18-2000 08:17:48
 Re: Re: 3pt wood splitter/front wheel weights in reply to Jim.UT, 10-18-2000 07:56:47
my neighbor saw a pair on a tractor parked by the road for sale (the tractor with weights). Since they don't add much to the resale of the tractor, he was able to by them for a fair price....I'm checking every N for them now.
Take Care
Steve
