Order Ford 8N Parts Online
8N Thermostat
Dennis Pierce
10-15-2000 16:38:49
Help!!! I just finished a '26 Ford T lakester hot rod using a built '29 Model A engine, B crank....etc. I have an aluminum head with an adaptor to use a single early V-8 water pump. The hose from the radiator to the pump is 1-1/2" ID. Can someone confirm that there is Ford tractor thermostate with a 1-1/2" OD that fits in the upper hose and if so, a source and the temp rating as to when it opens.
Please reply to: [email protected]
Thanks
Dennis Pierce
10-16-2000 10:31:45
 Re: 8N Thermostat in reply to Dennis Pierce, 10-15-2000 16:38:49
THANKS! Picked one up this morning and it fit perfectly.
Dennis0
yep.....Dell (WA)
10-16-2000 07:00:24
N-Tractor thermostat is hose mounted, 160 deg. $20. Make certain that you mount it for proper flow direction. It's not intuitively obvious. Good luck on your T-Lakester project..... .Dell
jim
10-17-2000 19:44:39
 Re: Re: 8N Thermostat in reply to yep.....Dell (WA), 10-16-2000 07:00:24
Is there a thermostat available from my local auto parts store or do I need to find a genuine Ford tractor thermostat?
Also, winter is coming. Is there any reason I should not use 5W30 oil in my 8N. I use it for everything else.
Dell (WA)
10-18-2000 01:00:38
 Re: Re: Re: 8N Thermostat in reply to jim, 10-17-2000 19:44:39
Jim..... ..boy, almost missed your question.
I doubt that you'd find the N-Tractor's hose mounted thermostat at your local "pep boys". NAPA maybe, they'd order it for you I'm sure. Check some of the sponsors of this excellent N-Board. About $15.
N's really need a thermostat, summer or winter. The oil needs to get hot enuff to vaporize the water that is a byproduct of combustion, otherwize the oil and engine innerds get all gunked up.
I use valvoline 10-40 in my 8N all year long. Of course we seldom see below 20 degrees, which is cold enuff. I think 5W-30 might be a little on the thin side unless your trying to start at minus 30, at which time, you're going to have other problems, like weak battery, low sparkies, gas that won't gas. Don't forget, oil besides being a lubricant, it is also a "coolant".
If you're just trying to get the tractor to start so you can plow the driveway, a 30 min job, or to muckbucket with the front loader for 1 hr. 5W-30 probably be ok. But if you were planning to do some serious heavy duty work, 5W-30 might just be too thin. But I sure wouldn't plan on putting 50wt oil in (grin)..... ...Dell
