Order Ford 8N Parts Online
52 8n Battery
CJ
10-14-2000 19:09:24
My 52 8n's battery keeps going dead (6V). I have to jump start it every time I want to use it. I replaced the wire harness last year. It just started doing this. If anyone could give me any ideas I wouls appreciate it. Thanks
Cj
Max
10-15-2000 05:46:04
 Re: 52 8n Battery in reply to CJ, 10-14-2000 19:09:24
A simple test would be to pull a cable off the battery while the tractor is running. If it dies you have a charging problem that you have to figure out. If it keeps running, check the battery to see if it's good. If it's good, then the charging system is weak.
Doug 8N Oh
10-14-2000 19:44:16
CJ a couple of basic things come to mind. How old is the battery ? Does you ammeter show it is charging when you use it ? Could be a dead cell in the battery, I suggest checking each cell with a hydrometer. Next make sure you are charging while running. Good Luck, I know first hand how a charging problem can be frustr
