Battery Sparks!!!
fred
10-11-2000 11:37:37
AS I previously mention, I rewired a 1952 8n 6volt. I noticed sparks when I put the negative cable on the battery post, indicating an electrical pull with the ignition switch in the off position. I checked the work with the wiring diagram and everthing looks okay. Someone on the 8n board told me to go to the terminal inside the firewall and disconnect one wire at a time until I find the wire pulling the current. As most know there are only three wires connected to this terninal. A switch wire, hot wire from solenoid and the wire that comes from the regulator marked battery. The wire from the regulator is the culprit! Of course if I leave this wire connected it will kill the battery quickly. So, this wire is now taped. Any ideas or what should I do now?
Franz
10-11-2000 21:24:36
 Re: Battery Sparks!!! in reply to fred, 10-11-2000 11:37:37
There's a real hi teck tool designed to solve your problem, and help you determine which wire is drawing the current. Since you have a 6 volt system, use a 6 volt headlight bulb.
1 make sure the headlight bulb is good
2 connect one side the bulb to the battery terminal, clip jumper works well
3 Connect the other side of the bulb to the battery cable. 4 If you are drawing current, the bulb will light, disconnect one wire at a time till you determine where the current is going. When you pull the correct wire, the light goes out.
5 If the bulb doesn't light, but you' still see sparks, substitute a smaller wattage bulb.
Claus
10-11-2000 13:23:55
third party image
The wire going to the bat terminal of the regulator goes through the current relay then through the cutout relay and then to the armature terminal of the generator. It appears that the cutout relay is welded shut.. You need to replace the regulator...
Happy Motoring
Claus
Paul
10-11-2000 13:20:28
I know this isn't the high tech.answer but i had
the same proplem,a good whack with a rubber mallet
on the alt. cured mine.
Fred OH
10-12-2000 06:18:19
 Re: Re: Battery Sparks!!! in reply to Paul, 10-11-2000 13:20:28
Paul, I had it happen to my Ferguson 20 and I whacked the regulator and that took care of it. Been three months and the battery hasn't run down. L8R----Fred OH
Paul
10-12-2000 13:00:42
 Re: Re: Re: Battery Sparks!!! in reply to Fred OH, 10-12-2000 06:18:19
We old country farm boys know how to get by with
baling wire and big hammer.
By the way mine has done it twice in the last
few years,casused it both times putting the battery in backards(may be alittlt dense sometimes)and i only said rubber mallet for the
engineers and city boys,i really used big old craftman one inch wrench.--ph va
Charlie in TX
10-11-2000 14:04:04
Paul, I am an electrical engineer. We call that a technical tap. You need 4.5 years of engineering school to properly administer that tap. Otherwise, you might let out the smoke that keeps those electronics work'n. We all know after you let out the smoke you have to go buy parts with the smoke still in them. lol
In all seriousness Claus has it right.
Jim K
10-11-2000 17:30:27
 Re: Re: Re: Battery Sparks!!! in reply to Charlie in TX, 10-11-2000 14:04:04
Hey Charlie I'm an electrician the next time I see
smoke coming out of an electric motor or any other electrical apperatus can I just wrap the thing as fast as I can with electrical tape to keep the smoke in. Or would it be to late.
And is there a company that reinjects these things with more smoke. Or is that what rebuilds are?
Jim K
Charlie in TX
10-12-2000 07:34:13
 Re: Re: Re: Re: Battery Sparks!!! in reply to Jim K, 10-11-2000 17:30:27
Yes, when they rebuild it they are putting the smoke back in.
