Order Ford 8N Parts Online
8N Front Loader
Yankinnc
10-11-2000 11:05:19
Hi Folks,
There is an add in my local newspaper to sell a front loader for a 8N. The price of $500 seems pretty good, but I don't know what to look for to be sure that it will function properly, and all the needed parts are there. Any advise from those who know?
Thanks,
Yankinnc
Kenneth L.
12-22-2001 15:17:33
 Re: 8N Front Loader in reply to Yankinnc, 10-11-2000 11:05:19
I own a deerborn model 19-59 front end loader and would like some info on how to hook up the hydrolics to a 1952 8N. I was told to chain down one of the lidt arms and hook the hydrolic pipping to the bottom plug in the hydrolic pump, is this correct? any additional info would be apprechiated. Reluctant to hook it up without advice.
Mad Max
10-16-2000 19:37:29
My 8N has a bucket w/ a manual release I wish it had a hydralic digging action but it doesn't,, just scoops and drops I still wouldn't want to be without it. I put heavy duty threaded pipe to attach the bucket to the lift arms that way I can remove the heavy bucket when I'm mowing for example.
Larry 8N75381
10-11-2000 19:53:36
Take a look at the photos in the photopoint album linked below. There are several close up shots that will give you an idea of what is involved. Most likely missing piece is the most important, it is the front support that is fastened to the front of the axle support. It also has the pivot pin attached, at least on many Ford/Dearborn models, so may not have been taken off when the loader was. The last two "photos" are scans, one of the figure from the assembly manual showing the support and one of the pages from the parts manual showing two different supports plus the pump with the coupling to the pulley. If the support IS missing, not to worry(?), because they can be fabricated, per John tOTG. He apparently has to do this quite often.
HTH
Larry
Vic
10-11-2000 17:31:12
Others on this board know a lot more about them than I, but there are a number of things to look for:
I've seen some which tap into the 3-point hydraulics, and are only usable if you chain down the rear lift arms. IMHO, this design doesn't do much for me.
A much better design, I think, is one in which the hydraulics are separate from the 3-point. This generally uses a front-mount hydraulic pump (connects to the crankshaft through the hand crank hole). A dedicated hydraulic reservoir and spool valves are part of the loader design, so you can use it independently of the 3-point. It's especially useful if, for example, you have a back blade or scoop on the rear that you want to use on the same project.
Some loaders have trip buckets, in which dropping the bucket to the ground "latches" it in place, and pulling a manual release dumps the load via gravity. Unless you're just moving material from one place to another, a hydraulically-controlled bucket is a lot nicer. You can gradually sprinkle gravel on ruts in the driveway, or use the bucket lip in reverse to level out something you've just dumped, or even get yourself "unstuck" by using the hydraulics to move the bucket and pull or push yourself to high ground.
Finally, some loaders have very wide snow buckets (often, these are attachments which just widen the standard bucket). Don't count on moving gravel or dirt with these wide buckets, since the load will be way too heavy for your tractor.
Rick
10-11-2000 13:20:16
All I know is that they are real hard on the front ends. Even though they made them for the 8N's the tractors weren't made heavy duty enough to support there continual use. Good luck What I've seen and heard via the Archives is they go for around 300-400.00.
