2N Brake Adjusting Assembly
ken
10-06-2000 16:57:48
While replacing brake shoes and installing Sure Seals, I broke the brake adjusting stem assembly on the left wheel (p/n 81T-2108). The parts manual shows a blowup of the assembly and it appears that p/n 9N-2043 can be removed, allowing access to the stem assembly. a) How do you get the cap off, is the cap reusable?
b) Can the brake adjusting stem assembly be purchased? Where?
c) Is the brake assembly adusters threaded the same on both wheels?
Thanks, got my sure seals installed with plenty of good grease. ken
Dell (WA)
10-07-2000 09:10:39
 Re: 2N Brake Adjusting Assembly in reply to ken, 10-06-2000 16:57:48
awe....$hit!!!
Ken.....as ol' Grampa Jones ustta say "if'n it wern't fer bad luck, I'd have no luck atoll"
ref: a,b,c... I suspect you're gonna hav'ta go boneyard pickin'..... probably take a portable drill with ya and drill out the rivets that holds the 9N-2040 brakeshoe adjusting Bracket that holds your broken 81T-2108 brake adjusting stem..... Dell
