3 Point Lift Function
Ted/Ga
10-05-2000 18:40:15
Hello All,
I have an 8N that I just bought. The lift will go up and down just fine, as long as the tractor is in gear. When I take the tractor out of gear and try to use the lift, it won't do anything. Is this normal? I have a 5 foot bushog on the lift, and I think that I remember the lift working just fine with the transmission out of gear while I was looking to buy the tractor.
Tim
10-05-2000 19:02:26
 Re: 3 Point Lift Function in reply to Ted/Ga, 10-05-2000 18:40:15
I hope you know that the clutch must not be depressed when using the lift in neutral?
Ted/Ga
10-11-2000 20:57:53
 Re: Re: 3 Point Lift Function in reply to Tim, 10-05-2000 19:02:26
Tim,
I settled the problem with the lift.....owner education. I was told that the PTO had to be engaged, the clutch disengaged and that it would pick straight up. It did (grin).
My brother tried everything except for taking his foot off of the clutch pedal. I told him about 20 times and, bingo! Thanks for your help. best- Ted.
Ted/Ga
10-05-2000 19:13:13
Tim,
Thanks for the pointer. I'll check it out this weekend when I am back in Alabama, where I keep my tractor. My brother has been using the tractor to bushog, and he noticed this. I've only had the tractor for a week, and this is not something that I have noticed. Thanks - Ted
