Lift Problems
Wildhefer
10-02-2000 13:46:59
Ok, I'll make a long story short,LOL! I got a 41' 9/2-N (2-N radiator and hood). My lift isn't picking up the wieght that I think it should. It leaks down also with a heavy load. Should it be a able to pick up a 350lb. roll of hay? And what is the lifting capacity for the lift? As of right now, it want pick up the roll of hay. It shutters and shakes when I pick up a two bottom plow. I replaced the relief valve and that didnt' help it much. Need some help. Oh, while I'm here, my alternator want charge, I got it converted to 12v and have a one wire charging system on it. If it is not the alternator what is it?? Thanks,
Wildhefer
Steve W
10-02-2000 14:04:44
 Re: Lift Problems in reply to Wildhefer, 10-02-2000 13:46:59
My 2N will easily lift enough that the front comes right off the ground.....I'd say my finish mower weighs 500 lbs at least.
Do a search for under "Zane".....he's a hydraulic system expert. His past posts will tell you all you need to know.
As for the 12V thing, I can't help you, but search under past posts, and you'll find your answer.
