Order Ford 8N Parts Online
8N Hydrolics
Davido
10-02-2000 05:52:23
I just purchased my first 8N. The hydrolics will lift a 5' bush hog to full height with no problem, but as soon as I stop it immediately(takes 2 or 3 seconds) drops all the way down. Does the sound like a pressure relief valve problem? It lifts quickly and all the way up, but just will not hold it.
Charlie in TX
10-02-2000 09:02:51
 Re: 8N Hydrolics in reply to Davido, 10-02-2000 05:52:23
It could be a pressure relief valve. To check it is potentailly unsafe but it can be done safely. First read the IT manual and learn where all the moving part are. There are 2 rotating shafts, one to the rear end one to the pto. Locate the presure relief valve. Second remove the right side inspection plate and locate the moving parts. Some of the parts will be bellow the oil level. Again locate the pressure relief valve. Third, with a load on the 3pt, like a brush hog, and your ringer on the end of the valve start the motor and pick up the lift. If the valve is bad it will blow your finger off the end of the valve.
Your problem is more likely a faulty ram. If while your hand is on the valve, oil is gussing down from the top cover, you need to rebuild your ram. When I rebuild mine, I will do it with parts from a NAA. They have rubber o-rings.
A third possibility is a cracked pump. Zane can answer this better but the crackes are usually in the housing where the valve mounts.
My lift takes about 15 second to leak down with a hog. I am going to live with it for a while longer.
Hope this helps and post back your result.
Salmoneye
10-02-2000 06:16:56
Mine does it too with the brush-hog.
However, mine will hold the rear snow blade for a couple of hours.
I hope you get some good answers, as I am very interested!
