2-n runing like a John Deere
Homeboy
10-01-2000 14:55:37
I have a 1944 2-n that the back two clylinders won`t get fire to. I have two turning and two burning, no fire on left bank of distributor. Itwill start with a 12 volt battery hooked to the started and runs and sounds like a J-D. I hAve good continunity on all wire the plugs are a little oil soaked but have cleaned them up the rotor and rotor cap seem great as does the coil. The only problem is no fire off left side of the distributor. Any help much appreciated!
Scott HouTex
10-02-2000 15:06:22
 Re: 2-n runing like a John Deere in reply to Homeboy, 10-01-2000 14:55:37
Continuity on your plug wires does not tell
you the condition of the insulation. The easiest
is to replace them unless you know the wires
are reasonably new and the insulation is good.
The 'after dark' inspection is a good idea but
you may not be able to see a leak inside the
wire tube.
Homeboy
10-02-2000 15:27:38
 Re: Re: 2-n runing like a John Deere in reply to Scott HouTex, 10-02-2000 15:06:22
Thanks to you all for the great advice , it was the plugs and I will definently do the night thing. A wonderful idea. You guys are great. homeboy
STUMP PULLER
10-01-2000 16:30:47
HOW MUCH SLOP IS IN YOUR DIST SHAFT? IF THIS IS A PROBLEM, YOU MIGHT TRY OPENING YOUR POINTS A LITTLE MORE. GOOD LUCK
homeboy
10-01-2000 17:16:57
 Re: Re: 2-n runing like a John Deere in reply to STUMP PULLER, 10-01-2000 16:30:47
Stump Puller Seemes normal but will check it out more closer thanks. Homeboy
Hartshorn
10-02-2000 08:26:02
 Re: Re: Re: 2-n runing like a John Deere in reply to homeboy, 10-01-2000 17:16:57
I guess I would change the plugs and maybe the wires just for good measure. Especially changing the plugs always helps something...even if not the primary problem the engine will run much more sweet. Distributor caps are pretty notorious for looking OK when they really arent. Try starting the tractor at night in the dark and look for arcing around the cap.
Kim Hartshorn
