8-N restoration
williy
10-01-2000 06:09:35
Need some advice on restoring an 8-N. I am not a wiz when it comes to sheet metal issues and therefore need to know this: My hood has a couple of areas where rust has eaten dime size holes through the metal, other than that the hood seems solid. What are my options for correcting this problem?
Dave Todd
10-02-2000 18:38:52
 Re: 8-N restoration in reply to williy, 10-01-2000 06:09:35
I thought I read somewhere on this board, a while back about somebody was thinking of making new sheetmetal patch panals for the hood. Maybe I was dreaming about it too.???? Good luck!!
Dave
Jess
10-01-2000 11:36:58
Williy
There are No questions that this board can't answer. I have found that Each and Every one, have done there best to encourage All new comers with there restoration.It may be just alittle paint Or complete from spindle to the draw bar and every thing in between.
Good Luck with your New 8N
Jess
AL@NC
10-01-2000 07:13:58
The body rot should be cut back to solid sheet metal and new sheet metal welded in to do the job right. If you do not want to attempt this your self you might take it to a couple of body shops for some estimates. Its not a big chore if you have the right equipment and with some practice.
