Linda, I have used anti-freeze in the rear tires of my tractor for years. I use the kind of anti-freeze that is not harmful to animals. Remember, Dogs have this love/hate relationship with tires. It only takes a "taste" of anit-freeze to lock down their kidneys...which is a slow and painful death. I use a plastic 50 gallon barrel from a car wash to mix the anit-freeze in. (they love to give them away) There is no need to mix the solution 50/50. That would be too expensive. I live in Amarillo, Texas. It never gets below -10 degrees, so I mix the solution for -10 degrees. If you live up north, you should mix it stronger. To pump the solution into the tires, I use the oil pump from a 350 chevy engine. I cut a small 1/8" plate to size, seal it with silcone, and bolt it to the open end of the pump. I braze 1/2" NPT female swivel hydraulic connections to the suction and pressure ports of the pump. I use a 1/4" pipe, with a pin through the end to extend the drive shaft of the pump. I use my electric drill to power the pump. To convey the fluid from the barrel to the tire, I use 1/2" hydraulic hose. To attach the 1/2" pressure hose to the tire valve stems, I use the hose end off a bicyle hand pump. You have to reduce from 1/2" NPT to 1/8" NPT to attach the fitting. I am sure there are other ways to devise homemade pumps. You just need a strong enough pump pressure to overcome the tire pressure as you pump the solution into the tire. Before removing the air from the tire, you should jack up the wheels, and block them up for safety. Don't *EVER* use cinder blocks or bricks to block up heavy equipment. They will break with out warning. Only use large wood blocks or jack stands. To remove the air from the tire, I use a device that can be obtained at any tire store or farm store, You attach it to the valve stem and use your air compressor to suck the air out of the tire. If the seal is too great on your tractor tire, your tire will start to cave in. It is best to break the seal by seperating the tire bead from the rim. That way, only air from the tube is removed. To prime the pump, I attach a garden hose to the suction end to pressure water into the pump and pressure hose. I turn on the drill to make sure the pump is turning the right direction. Then, I remove the garden hose and place the suction hose into the barrel of solution. I attach the pressure hose to the tire's valve stem. At that point, I am ready to start the drill and fill the tire. My NAA holds 25 gallon of fluid in each tire. Be sure not to fill the tire completely up. You want it to flex as you go over bumps. If you put the tire's valve stem at the 12:00 position, and fill the tire until fluid is just coming out the valve stem, that will be just right. You want each tire to have the identical weight, otherwise, the lighter tire will always lose traction under load and it will wear out quicker. Having the valve stem at the 12:00 positon is the perfect way to measure the fluid and to get the exact amount of weight in each tire. The water/anti-freeze solution weighs 7.3 pounds per gallon. So if each tire takes 25 gallons of fluid, your total weight will be 365 pounds. You will be amazed at how the extra weight will make your tractor pull more. A side benefit is that your tractor's tires will last longer because they are not constantly spinning under a load. Hope this is helpful. Roland Jackson
