Terminal #2 on your alternator is called the "remote sense". Its an electronic trick. It is suppost to "sense" what the battery voltage really is at the battery terminal and usually is a small diameter wire because it does not carry any current. This can be very important when the battery is a long ways away from the alternator and the large charge wire from the alt to the bat is subject to "line loss" because of the distance. This remote sense fakes the regulator into upping the alternator's voltage output to makeup for this very real "line loss" so that the battery gets itself charged. Battery is charged by having more external voltage than internal voltage. Generally, on your low speed N-Tractor 12 volt conversion, terminal #2 is directly connected to the alternator battery output terminal. The N-Battery is not very far from the alternator. So you don't have to worry about electronic trickery. Because your N-Tractor is a low RPM engine as opposed to high RPM automobile engine, terminal #1 is usually connected to the tractors ignition switch through a decoupling device, eather a diode or a dash warning light bulb. Without this decoupling device, you will never beable to turn your engine off because the battery will "backfeed" through the alternator to the ignition coil. Sometimes, they use a "1-terminal" alternator version for simplistic sake. It really has terminal #2 internally connected to the battery terminal where you can't see it. And terminal #1 connected internally too. General consensus on 12 volt conversions is, use the 3-wire hook up because of the low RPM's of the N-Tractor. HOWSOMEVER...if your tractor is already converted to 12 volts with just a 1-wire alternator, and it is working for you, LEAVE WELL ENUFF ALONE..... ..Dell PS.....you might check the "archives" at the top of this N-Board for more info on 12 volt conversions and all the troubles that the electrically challenged get into. I'm a 12 volt advocate for the "right reasons", that said, I'm still looking for the reason for my eazy starting 6 volt 52 8N.
