Jubilee 12-volt Conversion
JGTN
09-22-2000 15:22:18
When I acquired my Jubilee someone had previously converted it to 12 volts. I decided to add electronic ignition (Genessee Products). I also decided to use an internal resistor coil. After I removed the resistor to the coil, the tractor would continue to run with the ignition turned off. I then replaced the resistor to the voltage sensing terminal on the alternator with a diode (Radio-shack catalog # 276-1114). I actually used two diodes in parallel (since they came three in a package). Since the conversion, I now have no resistors, no points, no jumping around when setting the timing, and the Jube runs and starts great. Just in case anyone is interested.
