Mike..... .hope you N-joy your new toy...er...tractor. They are neat but have their quirks and ferbiles. BUT the parts are relatively inexpensive and eazy to find, besides all those neat 3-point implements to ponder over. From your description of 1 round of brushoggin and then you start to have engine running problems sounds like the frontmount ignition coil going bad on you. Unfortunately, they are not as robust as they could be. Its a time/heat related problem of about 1/2 hr or so to heat up the coil and melt the insulative tar and start to short out the turns and reduce the sparkies. Since you say you are going to replace the coil, you will probably solve your problems. The other serging/loping suspect could be the governor but I tend to discount that at this time because the governor problem should show up almost after start up and you claim a round of 'hoggin' before you start having problems. Re....Brushoggin...I hope you have an Over Running Coupler (ORC) on your 2N's PTO shaft. This is a 1-way rattaching device that prevents all that rotory energy in the hog from backfeeding into the tranny and causing your tractor to NOT SLOWDOWN when you clutch to slow for the corner of the barn, fencepost, irrigation ditch, creekbank, wifes car (don't ask). The ORC also prevents expensive tranny noises. $60 cheep, get one..... ...Dell, the self-appointed ORC safety preacher
