Order Ford 8N Parts Online
8N won't start
Walter West
09-17-2000 06:28:44
My late model 8N ran well till I parked it last fall. When I tried to start it this summer it did not even seem to fire. It turns very well. Have replaced the points, condenser,spark plugs,coil, spark plug wires. A spark plug laid on the head shows its firing. Drained the gas out of the carb and sprayed starting fluid in the intake and it would still not fire. I have the carb off for cleaning, but not sure it will work.
Hope its not compression, but the fact it ran so well last summer would seem to rule that out. Any sugestions. Walt.
Brad
09-17-2000 20:08:15
 Re: 8N won't start in reply to Walter West, 09-17-2000 06:28:44
Try squirting a little oil in the cylinders and then re-install the spark plugs. You might have washed down the cylinder walls. I've saved a few "bad" engines this way.
Salmoneye
09-17-2000 12:05:21
I am with Dell...Do a compression check.
My bet is that you will find the exhaust valves stuck 'up'
Dell WA)
09-17-2000 08:17:32
Walt..... .Check your compression!!! When an engine fails to start with quick start and you have demostrated that you have sparkies, best bet is you have stuck/gummy valves/rings specally since you claim strong running engine when you turned it off a year ago. Do a dry and wet (squirt some oil in the sparkplug hole), write down the numbers, Ford specs: 90 psi min across all 4 cylinders. If you don't understand the numbers, post to the board and ask for opinions.
One of the founding N-Board member used to claim that 90% of all carb problems were found and solved in the ignition system. Something to think about..... ....Dell
Dell WA)
09-17-2000 08:15:30
Ken
09-17-2000 07:24:00
I have a similiar problem, except my 8N was running fine last weekend. All of a sudden it started missing, and loosing power. I changed wires, plugs, and the rotor which was being chewed up inside. The new rotor is also being chewed up inside, is there a spacer that is supposed to be on the spindle? What is the correct firing order, I may have reversed the wires?
Dell WA)
09-17-2000 08:25:45
 Re: Re: 8N won't start in reply to Ken, 09-17-2000 07:24:00
Ken..... ..."The new rotor is also being chewed up inside"..... .ya' gotts a "bad distributor". This has nothing to do with the "What is the correct firing order, I may have reversed the wires?". FWIW.....firing order is 1,2,4,3..... Dell
Dell WA)
09-17-2000 08:23:42
Ken
09-17-2000 07:21:11
Gaspump
09-17-2000 13:44:18
 Re: Re: 8N won't start in reply to Ken, 09-17-2000 07:21:11
To address the spacer question you brought up. If your N is of the side mount dist. type, yes a spacer usually refered to as a clip is necessary between the rotor and the shaft. It fits on the flat of the shaft and clips around it at the lower end.
