Order Ford 8N Parts Online
8N missing after warm up
Keith
09-15-2000 12:53:29
I have a 8N that misses and dies after warming up.
Checked the gas line an all is fine so the next thing is replace the coil. I have decided to tune up with new coil, plugs, wires, dist. cap, ect. My question is what is the best way to get to these parts. Should the sheet metal be remove and if so what is the best way to remove the sheet metal to get to the distrubutor, plugs, ect.
Doug Ohio
09-15-2000 19:29:50
 Re: 8N missing after warm up in reply to Keith, 09-15-2000 12:53:29
Keith, do a compression check. If you tractor does not miss when cold, sometimes after the engine warms up, the head gasket contracts and allows a lea
Chris
09-15-2000 13:53:44
Actually it is probably just easier to remove the distributor and do all the work on the bench. You dont have to remove and sheet metal. Disconnect your coil take the rotor cap off remove the two bolts and you can do all the rest at the bench.
Good Luck.
Chris, MI
