Order Ford 8N Parts Online
8N reverse gear ratio and snow plowing
Mark B (PA)
09-15-2000 10:56:11
The reverse speed on my '50 8N feels about equal to the 3rd gear ratio. Anyway, I think this will make snow plowing a bit of an adventure this winter when using the back blade. Any tips for dealing with this besides slipping the dickens out of the clutch? I really don't want to fork over the $$ for a front blade setup if there is a work around. Thanks
mike
09-17-2000 05:18:35
 Re: 8N reverse gear ratio and snow plowing in reply to Mark B (PA), 09-15-2000 10:56:11
You should be able to plow exceptionally well with a backblade going backwards or forwards. You do not need full throttle unless you want to smash into snowbanks which if they are frozen will probably snap the pivot pin on the backblade (been there, done that).
I have opted to mount a 6-1/2' Myers snowplow on the front of my tractor, picked it up for $150 including the valve and pump. So good deals are out there, your 8N does not have hydraulics for external hook ups, but a pump such as I have could be connected to the generator with a second pully. Or an electric pump arrangement which are very popular now. Or look up under dearborn snowblade (dozerblade) in the past posts from last week, there was a drawing of the old dearborn blade with cables and how everything connected. With a few skills, didn't seem like it be hard to duplicate.
It is easier to plow with the front blade than back blade. I'll give you a few hints as I used the backblade for years and used it yesterday to spread some crushes stone in my neighbors new garage before we pour concrete.
Going backwards: Adjust the top link so that it is longer than what you would think you need. This puts the frame of the backblade really low, but look at the curved part of the plow. When agains the snow/dirt/whatever, the weight of the material in the curved part will prevent the blade from riding over the top and keep in tight to the ground. Most people try to shorten the toplink to "push" the blade down to the ground, but there is no downpressure. Do the reverse for going forward.
Good luck and have fun plowing. Snow season is just around the corner.
Mike
John
09-16-2000 05:51:13
This is one of the reasons why I prefer my 9N (with step-up) over my 8N, the 9N reverse is slow and safe, the way it should be. If for some reason I want a fast reverse, I can slip it in high range.
Nolan
09-15-2000 17:19:42
Well now, there's no rule that says you've got to fork over big bucks for a front blade. It depends on how high tech you want to be.
You can make a perfectly servicable front blade by putting your rear blade in front of the tractor, and running a pair of 2x4's back to the lift arms to push it forward. Hang it from a chain off the front axle pivot. It's not nifty or remotely adjustable, but it will work. You can even make your own special snow plow blade if you like.
Al in PA
09-15-2000 15:37:49
You don't have to plow at full throttle. With a set of chains and some calcium in the rear tires (or wheel weights) you will be able to push a lot of snow at a fairly low speed in reverse. I prefer to plow in second in a forward direction (with or without the plow angled). If the snow builds up enough to make your tires spin, just lift the blade, pull forward, drop the blade and push the pile off to the side in reverse. Also, if you are on gravel, reverse the blade so that the convex side is facing the direction in which you are plowing (won't dig up the stones so badly).
If you plow a couple times during a large snow, it will be a lot easier to handle. Plus you get to play in the snow more with your tractor.
acadianbob
09-15-2000 11:25:12
The only realistic solution is a "Sherman" type auxillary transmission with a "step-down" mode. Shermans are expensive if you can find one. For more info on this option, check the archives.
