Order Ford 8N Parts Online
Scallopped Wheel centers on 8N.. ????
Truck
09-14-2000 20:52:34
My 52 8N has wheel centers that are not round, but scallopped between the bolts that hold the rims to the disc. What would these centers have been correctly installed on? I have a feeling they got put on when the original rims were replaced.. ( Funny thing, the replacement rims need replacing now due to calcium....Oh well!)
Thanks!
Tom VB
09-16-2000 20:25:09
 Re: Scallopped Wheel centers on 8N.. ???? in reply to Truck, 09-14-2000 20:52:34
Hey Truck, thanks for asking the question. I have the same rims on my 1950 8N. I'm sure they were replacement rims since the outers are not original. I've wondered if they are acceptable as a restore item. I've been wanting to ask on this board but haven't got around to it. Last year when I bought my Jubilee, I went to replace the tires and the tire shop had to use a saz-all to get the tires off. It was also because of calcium. I'll stick to air in my tires.
raytasch
09-15-2000 08:25:26
I think the scalloped disks came out on the hundred series. My 850 has them and I know of a 600 with them. I have and early 4000 that has one scalloped and one solid disk. ??? ray
Jim.UT
09-15-2000 10:04:22
 Re: Re: Scallopped Wheel centers on 8N.. ???? in reply to raytasch, 09-15-2000 08:25:26
My 850 also has scalloped centers.
Tractor Rod
09-15-2000 04:09:04
Hey Truck those centers are for a massey ferguson. Like a TO-20 or 30.
JimTN
09-15-2000 03:33:28
Sounds like 36-39 Ford car wheels. I believe the hubs and all will fit on the tractor spindles.
truck, not the front wheels, but as long as you mentioned it...
09-15-2000 07:32:25
 Re: Re: Scallopped Wheel centers on 8N.. ???? in reply to JimTN, 09-15-2000 03:33:28
Actually I was referring to the rear wheel discs as being scallopped..But as long as we are talking front wheels, I had a pair of model A Ford front hubs, five lugs, mounted on a parts tractor. I found out the large Ford 1/2 ton lug pattern was the same, and now I can use up all my wide 15 inch tires on my tractor. Might be just the ticket for someone needing "turf" style front tires.(Of course keep the 6 lug setup for later restoration!)
