Order Ford 8N Parts Online
8N starter gear-help
John
09-11-2000 19:50:03
Just tried today to turn the starter gear around on my 8N flywheel. Got the gear off, heated it some and then drove it back on. I let it cool but now it is not tight on the flywheel. Anyone had this happen? What now, get a new one?
Dell WA)
09-11-2000 23:16:28
 Re: 8N starter gear-help in reply to John, 09-11-2000 19:50:03
John..... ..false economy to turn over your flywheels starter ring gear. New ones are only $20, cheep. Get one.
Drill off your old one. Deep freeze your flywheel and heat your new ring. Expanding and contracting metal is what keeps the ring in place..... ...Dell
JerryU
09-12-2000 05:33:08
 Re: Re: 8N starter gear-help in reply to Dell WA), 09-11-2000 23:16:28
Dell:
Did that actually work to get the new ring gear on?
I tried the freezer and the oven routine and ended up heating the ring gear with a torch (per tOTG on a post). Most everyone has said you have to go the torch route.
Also, I didn't do it, but some of the board sages recommend putting about three tack welds to hold the ring gear in place.
JerryU
dave#1
09-12-2000 15:12:12
 Re: Re: Re: 8N starter gear-help in reply to JerryU, 09-12-2000 05:33:08
Same here, I roasted the ring gear in the oven for an hour and had the flywheel in the freezer over night, When I tried installing the ring gear, it just sat there and laughed at me !!! Use a torch.
later,dave
Michael Az
09-11-2000 21:07:02
I think you need a new one. The new one I just got has a bevel on one side of the teeth to help engage the starter gear. Sounds like yours has streached anyway.----- -Michael
